frickenbored
Hey everyone, I've decided to join an equipment forum because I've been trying to get my Case to start for weeks now with zero progress, and I'm hoping someone out there can help.
The tractor is a 1973 Case 350 crawler with a 188 engine. So some history...the tractor ran perfectly for countless years up until January of 2019. I live in Michigan so one day in January it was about 20F outside and I wanted to plow some snow. I had the case plugged in and it started with no problem in that cold weather, about 30 seconds of run time the engine started sputtering. That's when I saw a stream of diesel fuel spraying out of the return line via a loose return line fitting at the number one injector.
Once I noticed the fuel leak it was too late, the engine sputtered and died. So when I found that the return line fitting was not even finger tight I grabbed some wrenches and tightened all the return line fittings, I'm guessing they just came loose from all the vibration through the years. I tried getting the engine started for the next half hour but nothing happened. Not wanting to be in the cold weather anymore I gave up and let the tractor sit until spring.
Fast forward to this month. I've replaced the fuel filters, filled the fuel tank, bled the filters, bled the line from the filters to the injection pump, loosened all the injector lines and cranked the engine until fuel sprayed out, but this engine still refuses to start. I can get it running on a mixture of wd40 and starting fluid sprayed into the air intake so I'm thinking the compression is good and I find it hard to believe that all four injectors failed at the same time. When I crank the engine with the injector lines open I do get fuel at all four injectors but its just a small dribble of fuel, I've read that this is normal. Then I turned my attention to the return line after reading all kinds of stories about "mouse turds" turns out this Roosa Master fuel pump doesn't have the return line check ball, its just a normal tee fitting that screws into the top of the pump. I've blown the lines clear from the pump to the injectors and from the pump to the tank and it just doesn't look like the return lines are plugged.
So that's where I'm at, I'm starting to think that the pump itself went out and isn't putting out the required 2600psi to open the injectors but what confuses me is that I do get some smoke from the exhaust pipe when I turn the engine over (I guess that could be engine oil left on the cylinder walls). Also I'm confused as to why the engine died in the first place from a return line leak. I've read that people often open the return line and let the fuel dump on the ground to get the engine running when they have a plugged return line.
I would be extremely grateful if anyone has any suggestions. Also sorry for the novel.
