Well, the honeymoon with my 1840 has hit a few bumps.
I went out a couple weeks ago and found a puddle under the back end. Seems that the suction hose between the hydraulic tank and rear pump sprung a leak and drained some of the oil. I got a new hose, replaced it and replenished the oil in the reservoir. I started it up to check for leaks, and then discovered antifreeze leaking from the radiator.
I removed the radiator and found the lower section of the fan shroud cracked and broken, and the front corner edge of the lower radiator tank scraped from fan contact. Checked fan, hub, etc. and everything was tight. No idea how the contact occurred. I took the radiator in to a local shop. Leak was where the fan had scraped the lower tank. That was repaired and I got a new shroud and hoses. Went to install and couldn’t get the shroud low enough on the radiator so it wouldn’t hit the fan. Finally, I tried to install the radiator without shroud just to get a better look, and found the fan is very close the the lower tank, if not touching. I see no way to move the radiator down, so wondering about finding a new, slightly smaller fan blade (maybe. 1/2” - 1”) to gain adequate clearance.
Has anyone else encountered similar issues?
