Hello and Thanks for Any Advice: When I parked the loader, it would run and then cut off, then you could crank it back and it would run for a few mins. and cut off. I found out that the oil pressure was low making it do that so I filled it will oil. The air filter had gotten dirty and sucked a good bit of oil out of the engine and that's why the oil pressure dropped. That was corrected when I changed the air filters and filled it with oil. The oil pressure light does go out now when I spin the starter. I have bled the injectors 4-5 times and fuel does come out of each of the 3 injectors. It does not have any kind of bulb or pump to pressurize the system. All it has is the electric injector pump. I put a new Group 31 battery in it. I guess it could be the glow plugs or maybe the starter needs to turn the engine faster. Thanks Jdubya
