Buy the flatbed with knuckleboom, or dump without knuckleboom
Willie B
Mount Tabor VT
Electrician
Fire truck 2.jpg Faceless.jpg My first was A Chevy C65.
It came with a rack dump, a very versatile unit! It was built with GM 366 tall block motor. Had problems with holding timing. On the advice of a mechanic, I decided to rebuild the engine. My engine rebuilder felt it was a shame to rebuild a 366. He contributed a 427 block to rebuild. It was 5 speed Eaton with 2 speed Eaton rear. Uphill, or down it was lower gear all the way. It drank gasoline!
I now have a fire truck low mileage. I took the radiator out for recore, had a mishap when a hood cable released unexpected, so the grill is out for repair at the moment.
You probably need CDL to drive it. If you will tow a trailer over 10,000 LB rated you certainly will. The air brake question is a tough one. If I interpret correctly, in my state, under 26000 LBS no air brake endorsement needed.
Still available, would check with your tire suppliers. May also need the later Washer flange nuts.
22.5x6.75 White Steel 10x8.75" (Old Chevy 2 Ton Trucks) – Buy Truck Wheels
