This is my frist caliper job (Deutz-Fahr tractor). I cleaned the parts and need to decide if polishing the cylinder is required at all, and also if the piston is still acceptable, as I think it is.
The plated piston hasn't been polished yet, something I intend to do with 400 or 600 grit tape or just buffing. The plating faults are at the edges where the seal placed in the cylinder groove will never ride.
The cylinder wall was never plated or polished (I blasted it ligthly) so do I really need honing or polishing (it's the piston that slides against the seal and not the cylinder). If I should resurface it, what tool? It's +/- 60mm id so maybe a 3/4-2.5" honing tool (amazon), what grit stones and where can I get such stones?
The plate under the the piston is from the seal-kit I bought, what is it's exact purpose?
Thanks for any wisdom
