John Shipp
X2.2 lbs per kg = 47500lbs
I read a bit of IH history. The first of their track loaders were converted bulldozers. With grouser tracks they were ripping lots of drivetrain parts up. IH shipped them off to fitters such as Drott where the shoes were changed to three bar. A track loader turns more than a dozer. Might it be the three bar shoes making the loader feel under tractioned. Is tractioned a word?A little off-topic, but from the physics standpoint it all boils down to power, weight, traction, and hydraulic power. My little JD 350 three-cylinder gas machine is far better balanced than my several times bigger Cat 955K. The 350 will lose traction (in average soil conditions) just about the same time the engine bogs down. If I'm pushing down a tree, everything seems to be just in balance. A few weeks ago I pushed over a walnut cluster--7 trunks from one root system (they were all about 8" diameter)--and that was about tops for the machine. But it managed. Scale that tree up the same ratio as the 955 to the 350 and I don't think the 955 would have managed it.
It's much more than just weight and hp--it's the drive train, the gearing, the ground-engagement, and how it all balances out. When you get a machine that is in balance, it just feels right. The 955K just doesn't feel as right as the 350. Had a Cat 12F grader, too--and that was a lot of fun and seemed very balanced, though it could have used a bit more traction (i.e. new tires!).
