"Bomb Steer" lowbed trailer???
Discussion in 'Trailers' started by tractorfactor, Apr 10, 2017.
  1. tractorfactor
    tractorfactor Member
    Feb 17, 2014
    9
    Washington
    What the heck is bomb steer? Heard this somewhere but no one I've asked can tell me - including google...
  2. lantraxco
    lantraxco Senior Member
    Jan 1, 2009
    6,678
    Elsewhen
    As a WAG, they may be referring to the bomb carts with front and rear axles pulled by small tow tractors. I believe some had a steering linkage setup that when the front axle steered one way the rear steered the other, you could pull the whole train in a circle. Others were a kind of wagon steer. YMMV, I may be all wet.
  3. JBlackwell
    JBlackwell Well-Known Member
    Jun 1, 2009
    99
    Daingerfield, Texas
    If you are talking about a heavy haul lowboy trailer with a rear booster/stinger axle group then you are referring to what people call a rear bump steer option. That is when you have hydraulic rams on both sides of the spreader bar with a self-contained pony motor to power the cylinders and allows you to hydraulically straighten the stinger axle group in a straight position in order to back up in a straight line. Now almost all pivot style stingers have a manual or air operated pin to lock the spreader bar in a straight position, but they are not engineered by the trailer manufacturer to be used when loaded, only unloaded.
  4. JBlackwell
    Jun 1, 2009
    99
    Daingerfield, Texas
  5. Junkyard
    Junkyard Senior Member
    Jun 5, 2016
    1,091
    Field Mechanic
    Claremore, OK
    Example 1. Etnyre lite weight....
    Example 2. Cozad...
    What's up Blackwell!
  6. JBlackwell
    Jun 1, 2009
    99
    Daingerfield, Texas
    Hey there.
    Yeah, when this guy said bomb steer that is the only thing I can think of that makes any sense on a lowboy trailer. I couldn't find a pic of a Kalyn to use like the one you had.
  7. Junkyard
    Jun 5, 2016
    1,091
    Field Mechanic
    Claremore, OK
    That's all I thought of too was bump steer. Who knows though.
  8. DMiller
    DMiller Senior Member
    Feb 22, 2010
    2,008
    Retired
    Not seen a steerable three axle jeep, pretty handy.
  9. Junkyard
    Jun 5, 2016
    1,091
    Field Mechanic
    Claremore, OK
    Bump steer on a west coast trailer is handy. It'll help backing empty loaded, you can almost steer it like a full steerable trailer. Loaded is another story depending on how big the cylinders and pump is. I had a trailer like the red one, great empty and all but useless loaded. My Kalyn 13 had bump steer and it was bada$$. Giant cylinders and a 23 HP motor running hydraulics. The lighter setup only had 5.5 HP and the barrel of the cylinder was just slightly larger than the polish rod on the big setup......
    old-iron-habit and DMiller like this.
  10. DMiller
    Feb 22, 2010
    2,008
    Retired
    I was used to the old Load King drop necks and folding neck low boys, you all are so lucky.
