DozerTech78
Im working on a BOMAG roller, its having issues with blowing fluid out of the cap at times, so the cap/breather was replaced a while ago and it made no difference. There is a substantial amount of pressure that is building up inside of the reservoir. If you put a rubber glove over where the cap goes, it will blow up like a balloon. The fluid is foaming badly and you can watch very small bubbles come to the top over time. This leads me to believe that there is a leak in the suction line, aerating the fluid and causing excess pressure in the reservoir. My question is, would pressurizing the reservoir with shop air be an acceptable way of checking for leaks in the suction side?
