The a/c compressor is not turning on. The fuse was melted so i repaired that. I checked voltage a compressor with it unplugged. I only have 8 volts. I checked voltage leaving a/c relay i have 14 volts there( have engine running when i am checking these readings.) i found a plug behind the battery that was melted so i cut the plug out and spliced wires together. I also only have 8 volts at this plug for a/c. The wire leaving the a/c relay is number 1000-1. Where does this wire go to from relay? It is not one that i have at plug behind battery. I have jumpered low pressure switch that didnt make a difference. Any help would be appreciated.
