I have a 2005 bob at s175 with the foot controls for the bucket. I am having a problem lifting it doesn't seem to have the lifting power it had before I pulled out a bunch of bushes in front of the house. It used to lift the back tires right off the ground if you tried to lift something to heavy now the bucket goes up untill there is to much weight and stops and won't lift rear tires off the ground. With no weight it will rise up all the way. The engine does not seem to bog down when there is to much weight the bucket just doesn't go up any more once in a while it works great and lifts rear tires right up but not that often.
