Hey team, new to the forum. I recently purchased a 2005 Bobcat S150 on auction. It was not operational upon purchase so I had to forklift it onto my trailer. I’ve got it started but upon start the tilt cylinder goes into dump mode, lifts the front wheels off the ground, and the tilt pedal seems stuck. I can unhook the lines from the cylinders and lift it manually back into place. Start it up, same thing. I lubed everything up with Free All hoping something was just stuck. I pulled the side plate and everything is actually really clean around the control valve. The machine had an engine replacement shortly before I bought it and the job wasn’t finished (all brackets not hooked up, drive belt wasn’t adjusted). I finished all of that to get it running. What do I need to check? Air in the system? Solenoid issue? Thanks.
