Bobcat fuse panel
rmllarue91
northeast pa
field technician
Hey hef looking for wire terminals for fuse panel. I got three machines that the fuse panel between your legs is needing replacement. 6673200 is the housing for fuse panel but can't find terminals. Two types of terminals ones for common blade type fuses and the common 4-5 post square relay.​
crewchief888
NWI
pre terminated ends are available through bobcat
they are part of the wire harness repair kits.
it's a matter of figuring out what PN's you need
terminals are usually 10 in a package.
