Hello all,
Purchased a Bobcat E50 this spring and just finished the 50 Hours service. Everything went well but the last time I ran the machine I noticed fluid build up around the radiator cores. Upon close inspection I concluded fluid was coming from the Hydro res breather cap. The fluid level seems to be in the correct level using the manuals procedure. I did notice that after running the machine for a while and loosening the breather cap the tank seems to have a lot of pressure built up. Not sure if this is normal or maybe the replacement breather cap is defective.
Any help would be appreciated
