Bobcat 873 G fuel solenoid
jorswift
Indiana
So when I got the machine, the solenoid plug was burned up. I ordered a new plug and adapter to solenoid. The plug is a 3 prong, with 2 wires. Does anyone know the correct wiring orientation? I see there are some small numbers on the plug. My old one was so bad it wasnt even attached. Any help is appreciated. Thanks.
jorswift
Indiana
Here is the plug that I need to wire up. I only have 2 wires and 3 spots. The log ten goes to the adapter to solenoid. Solenoid is a 2 pin plug style.
jorswift
Indiana
1 pin should be ground. The other should be hot from ignition
So I cannot get power to the original solenoid wires. I checked the fuse, relay ect. and nothing. So decided to go from the hot wire from the alternator when key is on. However, I get power to the solenoid, but they do not open up when key is in the on position. I tried it with 2 different solenoids. Would both leads be hot? 1 to open and 1 to hold?
Vetech63
Oklahoma
Unlikely on that type. Probe each wire.......one of those should be ground. What I don't know is if it runs through a relay which I would say it does. Trying to jump power from other areas is just going to make things more confusing. Do you have a wire schematic for this machine?
jorswift
Indiana
Figured it out. Has one hot and one negative. Wired from a hot wire from the alternator with key on. Works properly now. Thanks.
