Bobcat 863 steering issues
712alberta
Alberta Canada
I don't have a lot of hours operating skid steers of any make, but at the facility I'm working at this winter, they have a Bobcat 863 that has some issues with the steering, amongst other things. When I push the hand controls forward, all the way, the machine will veer off to one side or the other, then abruptly steer to the other direction. Does the same thing in reverse. It gets worse if your trying to grade, or push into a pile. Is this a sign of something failing? or of something out of adjustment?
Knoxville TN
Service Manager
Will it hold neutral? Or does it creep in random different directions when you have your hands off the sticks?
712alberta
Alberta Canada
No, it won't hold neutral. You have to work the controls to find a spot where it won't move. It fights the safety and trys to move when the lap bar is up. You want to be in the machine when the engine is running, or it will start creeping away. Never in the same direction.
The hour meter says 4300ish hours. To me I think it looks like the machine has either been rolled back or the meter has gone around once. It's in rough shape
