frankenstein
I parked my 863C (1997) for about a month and now the tilit/ lift doesn't work...it wants to but only tilts and lifts about an inch or so. It has Foot controls only for tilt lift.
The BICS valve light blinks 3x (Valve output circuit shorted to ground) all other lights ready for operation and the machine can move forward and backward but just not the tilt and lift.
I tried replacing the tilt lift solenoid coil but that didn't fix the problem. I also looked for bare wires and fluid levels but that all looked ok. The error code indicates 3 blinks with key on position before and also after started.
If you have ideas I would really appreciate as much specifics as possible as I am not an every day mechanic. Thanks in advance.
