Hi Folks-
I recently replaced the main drive belt along with all the other belts and followed the manual to use a pry bar and move the tensioner against the belt beyond the 1:00 position. The pointer didn't move much, so I took the tensioner back off. Took off the dust cap. Bearing looks OK, there was a little grease spun out at the top of the bolt,etc, but the real issue is when I flipped the idler over and found the hub assembly cracked where the pin fits in to hold the spring. Not broken off, just cracked. I'm thinking that the machine ran for awhile with no tension on the spring. Anyway, wondering if I could spot weld it to save the $128.00 from Bobcat to replace the hub assembly. It's not so much the cost of the hub but taken it all apart. Also, what should be greased in there and how much tension, if any, should be put on the spring when I put it back together? Is it hard to take the thing apart? Thanks!
