madtabula
Hi everyone, Need some help with a Bobcat 325G. It is a 2007 ser 234113977. When I purchased it used several years ago it ran fine. Turn the key wait for it to "spin" up warm the plugs and then turn the key to start. Now I turn the key and nothing. I dont ket the "spin" up where the dials energize us and then rest to where they belong. For example the fuel gauge dial when you turn the key will go all the way full then go to wherever it really is. Thats what I call spinning up. Now it just does nothing I'll see some lights flash but then nothing. Sometimes I let it set like that for hours and I'll see that it has spun up and the machine will start. Understand this is not a battery problem or starter problem. This is BEFORE you start. The machine will turn over but it will not start unless the gauges are spun up. This issue is getting progressively worse. I have checked all the fuses and they are fine. Do yall think its the entire controller panel? The numbers LCD display never worked. Its a prior Sunbelt Rental (green) and they taped over the LCD and put their own mechanical hours meter.
