I wonder how big of a cylinder bench you need for 60 ton cylinders? The 2nd pic. is a 140 yd. bucket for the 3850B the cylinder is used on. The last pic. is one the cylinders to pick up Big Muskie. Both machines used 4 cylinders. Big Muskies hydraulic system held 26,000 gallons!!! It operated at 2500 PSI and each jack uses 6 180 GPM Vickers piston pumps which were driven in pairs by GE 600 HP motors. You sure wouldn't want leaks on that.
