packratc
Ran out of fuel. Bled the system 100 times or 15. Used ether several times. Burnt up starter. Had injectors tested & replaced two. I'm an idiot! Finally replaced fuel filters & it started. Lots of blow by. Running on 3 cylinders. Number one seems to be the one not firing. It's one of the older injectors. Big holes in old muffler. Seems like fuel is building up and then firing and flames can be seen in the muffler. Sounds like shotgun going off over and over. Let it run pretty fast for a long time and kept bleeding injectors. Smoke everywhere. Fun thing is that it ran out of fuel coming out of a half-dry pond. It has no brakes so it nestled itself near the bottom. We're having rain quite often. It's in red clay at about 20% grade, sideways. Can't pull its self out of the hole. Did I tell you that I'm an idiot? Give me your best shots. I deserve them. I don't know what elso to do except have that injector checked again. Don't have a compression gage. Where's the cheapest place to get a rebuild kit. Is it a bear to put in liners, pistons, rings & bearings at 20% grade in the red clay mud? Above saga has taken three weeks between rain and life. Thank you for your thoughts, prayers, and hopefully helpful advice. Packratc in Tennessee.
