zlssefi
Back in business! I changed out all the parts including seals, gasket, 2nd turbine and splines and lock tabs. Everything works flawlessly now! Fire away if you have any questions!
Hey guys,
Years ago i bought a TEREX 7231 BA wheel loader with the two speed allison tt2000 series transmission in it. It has been a good machine for many years. After this past snow storm one of my operators told me that it was very slow in 1st gear and reverse, but 2nd gear seems more normal speed wise. The only thing ive had time to check so far was to verify the complaint and to check the clutch pressure on the dash which appears to be normal in neutral, 1st, 2nd and reverse. Im going to drop the filter and fluid tomorrow to start looking into this but do these symptoms ring a bell as to what the issue might be? Just seems odd that both 1st and reverse are equally slow.
Thanks in advance!
I'm pulling the engine as well, I am hoping the TC and the housing can be slipped off to get me to the suction tube.I had to take torque converter apart so I could take tc housing off. It was trickery still in machine , but we did it, our engine was out of machine at the time. The transmission remained in machine
