Q1. Curious: we use 3' ladders for a lot of things ... any idea why it kicked out?
Q2 Hey, thanks for showing the pics of the connections. Do you regularly use the No Ox? I completely disassemble the bus works, lugs, connectors etc, coat all with the NoOx, then reassemble. Regardless of copper or aluminum wire.
Reason: after some time, the threads on the connections begin to freeze up, etc. The ones with the No Ox always have threads in good workable condition.
Q3 On the subpanel, looks like the Grounding Conductor (nicknamed Green wire or Ground Wire) has yet to be run?
FYI 'a' I figure that breaker panel is a service entrance panel with the meter set on the other side of the wall? On the southern west coast (SoCal) we use a lot of combination meter, main, and breaker. I guess it is all about the weather (or lack of it)!
FYI 'b' The use of the yellow pull rope around these parts is taboo, must be the flat woven polyester pull tape. "Rumor has it" the pull tape won't cut the conduit like the yellow rope. Haven't seen yellow rope in a long long time, all remnants having been used up and discarded quite a while back.
