bigboytoy
sorry ....This whole time I thought we were working on a pre historic wheel loader. What a difference a model and serial number make.
WRONG!its the vane pump
Yeah whateverI am an AC guy ...
WRONGits the vane pump that doesn't like dirt and heat
LOL....WRONG againwell its definitely a vane pump .
Still wrongthe vane pump is a bad idea ... poor engineering
JFC.......how many times can someone be so wrong on the same dam thing?what I was fishing for is information on vane pumps .
LMAO......this is some BS!... I guess I didn't say "vane pump" enough nor do many people have experienced the poor engineering of the "vane pump" ... so lack of understanding leave some to shoot the messenger
Easy bro, remember how long we were grounded last time. Say it with me, "goosfrabba" BWAHAHAWell......
WRONG!
Yeah whatever
WRONG
LOL....WRONG again
Still wrong
Well over 100 years of experience in this field from responses on the first 2 pages alone.......you literally ignored all advice. You seem to be very convinced of your own superiority.
I know guys like you very well. They are know-it-alls, and can be taught nothing. I don't even know why your here asking anything.......no one will have YOUR answer.
Me move along? OH HELL NO. I'm going to continue to point out everything you don't know or are doing wrong. I wouldn't miss this train wreck for all the tea in China!!
I thought temperature regulated the expansion valve but still had a baseline operation dictated by pressure. But since N is inert and doesn't react to temp and pressure changes it would essentially jam up the works. I'm still learnin stuff. Good catch.Well, while we're at it, operating the system with nitrogen in lieu of refrigerant does two things:
Doesn't suspend the oil droplets that circulate along with the gas.
Doesn't actuate the expansion valve, as the valve cycles on temperature, not pressure.
To answer this question, there is a jack that needs to be purchased to raise the cab. Using this tool is the safest way to tilt the cab. When cab is raised, there is also a safety prop on the underside of the cab that needs to be engaged.Maybe MG2361 could tap in on the safest method to tip the cab.
He explained it very clearly……I believe your reading comprehension needs repaired before your a/c system. Please carry on…….now I see the tilt tool where it is located from a helpful member ...
