rmllarue91
Will post s/n soon machine was moving fine and both sticks went unresponsive check all fluids steering works fine solenoids On main control have 90 ohms with it running 3 ohms with key off on ground circuit. power side has 5 volts with key on or running neither change when controls are moved. Checked fuses. Plugged in et same code under engine and transmission ecm code was implement control update erratic. This is the odd part can't find anything in et with implements can't calibrate them can't watch them I don't have a book on anything with the electronic controls but have calibrated them with out issues. Any one feel like schooling me on these systems are these all ecm controlled what inputs. the lock out switch has good ground on 200 wires white and green both have 5 volts don't not remember the purple or other black . okay enough rambling any input welcome not familiar with these I'll post serial number asap.
