junior
http://i20.ebayimg.com/02/i/000/78/49/3b81_1.JPG
http://www.machinerytrader.com/images/Machinery/fullsize/74251613.jpg
i am not talking about their capacity, but about their design differences. look at the photos above, i think z linkage is better for high force, also double z linkage is better than all. so the smaller 988B is be better for under heavy works? also the main boom of 988G is to long(you can understand it that in the photo above the distance between the front tire and the rear of the bucket is to much), i think it is designed for loading the bigger trucks-the higher ones, but i think is a mistake about stability.(on the other hand i see a 988G with a shorter main boom in this picture but it is attached a fork on it for big stones; here; http://image44.webshots.com/45/8/2/...rides/rides/&track_action=/Shortcuts/FullSize)
also 988G has only one joint between main boom and bucket, but the old type loaders like 988B has two. and one joint is means unbalanced force especially if you are filling or forcing the bucket with only one side.( you can see the difference here; http://image46.webshots.com/47/0/50...rides/rides/&track_action=/Shortcuts/FullSize
the one in the middle is old type like 988B(better i think) and the sides are like 988G)
and here comes three questions;
1)at last what do you think, which one is the better,988G-988B ?
2)which loader is the best you think in 988G's class? CAT 988G, CAT 988H, VOLVO L330E, KOMATSU WA-600, KAWASAKI 115-ZV, or any others.
3)do you know about fuel consuptions of them, can you compare them(between these models and then generally between differences of the manufacturers)(for example is it true that cat machines' consumption is not economical.)
thanks for comments...
