Would it help to replace the hyd oil with higher visc? I got the cat from a dealer in Kentucky. I don't know what they used for oil, but maybe they had higher temp oil in it. Like I was saying, it reacts and drives and pushes faster when its cooler. But after the trans gets to operating temp, it gets slower, but still has the pushing power. It started all this after I ruptured a drive hose and had to refill the reservoir. I don't have access to the testing equipment required. Is there adjustments I can make, like the main pressure relief valve or the underspeed cut in valve to see if it helps, or makes it worse.
