houser
Which tank is it that is under the belly below the driver's seat? It has about a 2" drain plug?
AllDodge, do you think 10 or 15 W is too thin for warm weather use?
Are you saying the tranny oil can leak into the final drive? Does the fact that I seem to be over full in my "case" or rear end play into the possible issue? If so, what might cause this or better yet, what do I need to fix?It can run into the belly pan, leak to final drive, into cooling system from oil cooler
AllDodge, thanks! How much of job is it to replace seal 17? Wh as t problem will happen with mor oil in the rear end than what should ?Yes seal number 17 is what keeps the oils separated and if it fails then tranny leaks into bevel gear.
Under the machine there is a plug (item 27) for the bevel gear to drain it. It way be covered by a access plate with smaller bolts
The final drive fills plugs (item 25) are on each side
View attachment 217467 View attachment 217468
