I've got an 863F with AHC.
Drives fine but no tilt or lift. Valve lock light does not turn on at all(not blinking)
back-story
The tilt and lift was locking out whenever I used the tilt so I replaced the tilt actuator which was full of hydraulic oil with a new one.
While at it I also resealed both the tilt and lift spools.
(and replaced the shield/kick-plate and gas sprigs for the drive linkage.)
Once I put everything back together, the valve lock would no longer turn on at all.
*I checked all the grounds I could find.
*cleaned harnesses that were less than new looking inside
*installed new heavier gauge ground cables to the new battery.
*I then bought a new BICS valve lock solenoid, still no difference.
*Then a new BICS controller, no difference.
*and most recently a new AHC controller, no difference.
Thinking that maybe the new actuator the dealer sent was somehow not right I just plugged in the old one yesterday which I cleaned very well.
but still nothing.
Below is a Schematic for wiring going in and out of the AHC controller.
My readings where inconsistent with many of the values in this schematic which is why I bought a new AHC controller.
I'm planning to do the readings again soon to record and post here.
back-story
but still nothing.
