stevep3916
i have bought an 863 bobcat with advanced hand controls from a friend the bobcat quit on him wouldnt restart nothing in cab had any power i have replaced battery cleaned all battery cables and ground connections checked main 100 amp power fuse all ok at fuse block power to all fuses and relays machine will turn over if i bridge over starter relay display on the left in cab sez input only cant get 1 conn off controller in the bottom left panel appears nut is turning on backside of conn best i can get fron bobcat dealer is bring your check book and come on down which is a 4 hour trip 1 way any body have any ideas thanks steve
