740B blowing fuel
Aussietech
Calgary Canada
I have a 740B haul truck
S/N T4R01716 roughly 13,000hrs
Machine is blowing blue/white smoke. We have replaced the head gasket,
We have replaced all 6 injectors with remain ones from a local diesel shop ,Have done injectior cut out tests, passed every time.
Have had the DPF filter cleaned,
We have installed new EGR cooler with new
Have put coolant pressure gauge on for 12hrs no drop in pressure
No coolant in the oil
No loss of oil
At full rpm the smoke goes away, when idling the smoke comes back,
Getting close to engine overhaul time with those hours.
Before or after it started blowing smoke.?
How a bit of back story about how the smoking at idle got to this point.?
Got worse & worse over an extended time (weeks, months, longer.?) or literally appeared from one day to the next.?
Is the engine burning any oil.?
Do you have access to Cat ET.?
Aussietech
Calgary Canada
Replaced head gasket after it started blowing smoke,
Started smoking machine was shut down within a week, replaced head gasket, sent back to work for 3 days
Returned to work shop with lots and lots of smoke,
Cut out test said 1&6 injectors failed, replaced all 6 with rebuilt ones,
Blowing less smoke after that, but still enough to see it and cause a issue
Not burning oil
Yes I do,
Also pulled the engine oil, with less the 50hrs on it,
Smelt a lot like exhaust fumes in the oil
ahart
Indiana
A couple of questions:
1- do you have any oil sample data for this machine?
2- is there another T4R on site?
