621G injection pump
JackA
United States
Can someone explain how this injection pump works? I’m only used to seeing an external pump with hard lines so this thing has me raF3A09D23-65A4-459F-BC62-9FC16DEC8997.jpeg
Mobiltech
Sask.
There are 6 of these in a c15. Each one is pumped by the camshaft and a rocker arm so that part of it is much like a mechanical fuel injection pump.
In place of a mechanical rack to control fuel delivery the solenoid with two wires to it that you see on the side controls timing and duration of injection by closing off the drain port in the plunger and barrel section forcing the fuel to build pressure and open the injection nozzle at the tip. It is a fuel pump and injector in one unit.
The solenoid is electronically controlled by the engine ecm which decides when and how long to inject fuel. This controls timing and volume of fuel injected.
That’s basically how it works.
Cat in their terminology lists it as a pump group fuel injection.
