Hey guys, I'm more of a reader here and got all my info to reassemble my 580 after an injector pump rebuild. A little back story, 2 years ago I was working with it in our sugarbush and it died. Thought it was the filters but turned out to be the injector pump. Got it rebuild locally and then I found this site! I've done tons of reading and thought I had this so this past weekend I had some time so out to the case I go. Put the engine at 8 BTDC (pulled #1 injector and put a coat hanger down) got it close. Looked in the inspection hole rotated engine to 8*. Made sure lines lined up on injector pump. I was thinking to myself this may actually run. Opened the fuel valve, opened the bleeder valve on the top filter, blew into the tank to try and pressurize it, cracked the line out of the filter. Got fuel out of the bleeder screw, shut that cracked the line into the pump and fuel was pouring out. Disconnect all the fuel lines to the injectors and cranked the motor till fuel was spitting out of the lines. Kept cranking till the lines looked clear. Feeling good about myself I connected the fuel lines back up and........ nothing!!! Just turned over without even a hint of starting. Rebled the lines to the injectors one at a time (did this a few times) still nothing!! Last ditch effort I gave it a shot of starting fluid, still nothing.. So frustrating!! Any ideas???
