DirtyHoe
Hello,
I've read every thread I could find on timing the fuel injector on a 580C. But after reading I think I'm more confused because there are some machines at 8 degrees and others at 0 degrees timing on the flywheel.
Here is my confusion:
The valve cover gasket sticker says to time it at 0 degrees along with the service manual. I checked it and the timing is at 8 degrees so is it correct or wrong? It starts right up and seems to run OK. It does smoke a little and the muffler seems to always be somewhat wet. I can't tell if it's oil or something else. The coolant looks fine.
Is my pump the original or a replacement? It's a Stanadyne DBO-3205
Please see attached pictures.
On another note, I adjusted my valves and they were all considerably off around .025 to .037 instead of .012 for intake and .014 for exhaust. Did the motor get damaged from being so out of specs?
I haven't used it much because I have rebuilding most of the machine since I have owned it. Wish I could have afforded a better machine...
Thanks,
Steve
Thanks,
Steve
