580 ck torque converter
Tunneldigger
Southeast Iowa
Farmer with a job in town
I have a friend that has a 580 ck backhoe. He is wanting to get it running as it will not move. I said it probably is a torque converter. How hard is it to change and what is parts availability?
Billrog
Armstrong, British Columbia
band mill , backhoe and dump truck
Not bad took me 4.5 hrs. ( I'm not a mechanic ) might as well put in a new pump as well while it's apart .Need a micromotor when bolting up the torch to get it within 4 or 5 thou.
fast_st
Mass
IT systems admin
what's the trans pressure gauge say? there is a disconnector on the clutch pedal possibly that could be stuck, check the trans fluid under the steering column.
joe--h
Utah
Dos this mean won't run, won't start? Out of fuel, needs battery charged?
Why do you think it needs a torque convertor? Random guess?
Need a whole lot more info before random expensive guess parts throwing.
Joe H
