Knivens894
I have a 490E which started stalling under load. I had the dealer make a service call. He found the pump control module had failed. Purchased another module, installed it, and the machine worked fine for about 8 hours, then went back into the stall mode. Inspection of the control module shows it failed in the identical area as the first, burning up the 4 watt 10 ohm resistor and melting the diode next to it.
Has anyone seen this problem before? Any suggestions for finding the cause of these failures would be appreciated.
