hi im in another posting for my backhoe having no hydraulics
but i figured i might get more help quicker specifying my current issue
i have the pressure control valve still bolted to the backhoe as its too awkward to remove
but i too the plug out the washers that were behind it and the spring.
now the drawing shows washers and the orifice there andthen the valve but on here that doesnt work that way
so i have the valve trying to pull it out but it gets stuck you can only pull it out a bit then just sticks i tried a scribber in there as the picture shows the valve has holes and also like screws so i figured i could twist it out... nothing works
how do i remove it and clean it and hoping that my pressure problems is not the transmission charge pump
