297C skid steer no bucket or boom function
tractormech
florida
Hello all-I sure could use some help from you Cat guys out there- We have a 297c serial GCP01641. The bucket and boom function has quit working suddenly. When you release the parking brake/ hydraulic lock the machine will drive and steer but there's a cylinder symbol that stays illuminated now. The owner said it flickered a bit before as soon as the problem started but now it stays on solid. I assume it's an electrical issue but.....? does the computer control this? Maybe by a relay/fuse setup? I'm going to order a wiring schematic from Cat but I thought some of you might steer me in a good direction to start. Thanks!
The Peej
Connecticut
I would check the door switch first. The door switch will lock out the boom functions if it thinks the door is open.
