thepumpguysc
- Joined
- Mar 18, 2010
- Messages
- 7,555
- Location
- Sunny South Carolina
- Occupation
- Master Inj.Pump rebuilder
U r correct.. it should pump fuel weather the csd works or not..
Well I finally figured it out. I was fooled into thinking the injector pump had fuel all along because when I cracked the return line on the injector pump, I got fuel flow. I noticed that the return line "t's" into the injector return line AND into the return line coming off of the fuel filter and electric assist pump. That line was being backfed thru the "T" to the injector pump making me think the injector pump had fuel coming thru it. Once I saw this, I opened the intake line from the electric assist pump/filter housing and no fuel was coming thru even tho you could hear it buzzing. THe brass port in the electric assist pump has a pinhole in it that the fuel feeds thru to the injector pump. It was full of ice!Check out the electrical schematic that I sent to you, Page 13, Grid G-10.
The cold start device is shown as per the snip below. A temp switch with incoming Ignition-controlled power to it on wire 110-GN that when it closes energizes what is labelled as the "cold start Pump As" via wire G455-PK.
The cold start switch #2 is located on the end of the cylinder head as shown. I am assuming that it will be on the end of the head closest to the FIP location. It should have a 2-pin connector on it.
IMHO (and unless I'm missing something) you still ought to get smoke from the chimney when cranking even if the cold start device was not working.
See the attachment.Do you have a timing procedure for this?
This is bad news in a fuel system.It was full of ice!
well, the timing is on, I even pulled #1 injector to make sure it was actually misting on the business end. It was. #1 cylinder is loaded with fuel. I haven't done a compression check but the compression was good enough to blow the towel off the head when I had the injector out of it's port to test it.Here is the R&I for the FIP and the procedure to set TDC on #1 cylnder.
The engine only needs good compression, heat through compression, and fuel atomized at the right time to fire. One of these your engine isn't meeting. Does the engine smoke at all when you try to start it?well, the timing is on, I even pulled #1 injector to make sure it was actually misting on the business end. It was. #1 cylinder is loaded with fuel. I haven't done a compression check but the compression was good enough to blow the towel off the head when I had the injector out of it's port to test it.
Won't Combust the fuel. Checked the glow plugs- one was dead.
If I spray ether into the intake, it fires.
So, it seems as if the fuel into the cylinders is not getting to combustion point as the ether is at a much higher combustion point.
Short of a compression test, I'm out of thoughts on where to look next.
I'm with you on 180 out. but not on the engine.I still suspect a timing issue as in possibly 180 degrees out. Can you explain how you know it’s in time?
If it runs while spraying “fuel” in the intake that rules out compression or almost any other problem other than injection timing .
ok, but it is possible for it to be 180 out with the engine? meaning its delivering or firing on the exhaust stroke. I'm going to pull the valve cover and the #1 glow plug and take a look at the valves at tdc. Or is there another way to check the pump timing with the engine timing? I've heard of a pulse indicator but there's got to be a way to check if it's close without one of those.It IS NOT possible for the pump to be 180* out of time..
It fires all its cylinders every complete rotation of its drive shaft..
So, I took another look at timing, The 33 on the idler gear lines up with the other 3 on the IP every 15 revolutions of the IP. so you can't just set the 3's to mesh and call it good. You have 14 chances of being wrong. They have got to line up when the cam and crank lines up with their marks on the idler gear. Since those gear diameters are all different, that happens at different number of revolutions for each one. I don't really want to pull the front engine cover to see when those line up so I can set the pump accordingly, so I am waiting on a bore scope and thinking I can snake that in thru the FIP gear cover and watch for alignment that way.If I’m not mistaken, the 33 will line up with another 3..??
