Blacktoppaver
Hello
I have a Wacker Neuson rd11. The vibratory is not working correctly. I replaced the plastic coupling that connects the exciter motor and drum of the roller. Before I put it back together I pressed the vibratory switch to make sure the motor still turns which it does. I also changed the hydraulic filter when I was at it. I put the assembly back together but it still isn’t work correctly. Is shakes slightly but seems like is not getting full power. I checked all the hoses leading to it and it is getting hydraulic. Just wanted to see if I’m going in the right direction.
Thank you
Thank you
