hey guys, I'm new here and am having a problem with my 05 bobcat t190 with 2200 hours on it. 3 weeks ago I started it up, let it run and went through the motions of testing everything....and everything checked out.
The unit sat for 2 weeks, went to go get ready for the snow and pulled the skid out of my garage, started it up, and the left pedal won't release, it's as if it is locked up but the tilt works fine.
so I tested voltage at the spool lock relays, both were getting voltage. I tested each relay and could here them firing, but ended up replacing both just to be safe. still no luck, and even with the spool lock relay out I wasn't able to move the pedal. the linkage arm doesn't seem to be hanging up on anything, and my next step is to remove the linkage arm and see if I can push the plunger in manually. has anyone else had similar issues and can point me in the right direction? I searched the internet and everything I read said spool lock relays, but that doesn't seem to be the issue here. any help is greatly appreciated.
