Other than a good look at the bottom, and you say it's 70%(?), then that's got plenty of life left in it. Do the pins look worn on the drive side? Need to be turned yet? Chains in good shape? Sprockets? can you rock the pads side to side excessively? If all those things check out good, next would be:
Leaks.
Engine & pump cleanliness.
Service records availability.
Bucket wear/tooth wear, etc.
If it all checks out, then this ought to be a good piece for you. The one owner situation is also appealing.
Watch the Amulet thumb though. It's O.K., but they're a little light in the ruggedness department. We have a new 307 Cat with an Amulet Hydro thumb, and unfortunately when it was installed, no one took the time to check the hydraulic pressure. The first guy to run it was me, and I was thinking, wow, this thing really will grip, I'd better be careful. It is in a rental fleet, so we didn't get a chance to check the relief pressure on it.
The second guy was a rental customer who didn't have the same attitude as I did, went grabbing stuff as hard as he could, and called us to tell us that the thumb ram was bent in a horseshoe. We replace the ram, rewelded the plate onto the stick, and cut the relief pressure from 4400 psi back to around 1400 psi to eliminate any more problems.
The factory steel plate that welds to the stick on these Amulets are way too thin in our opinion. we have a 312C with one also, and it was ripped off the other day, and we had to glue it back on with the electric glue machine...:Banghead
Good luck with your endeavors.
