Thanks truck shop, I wish all my questions could be answered with one word....
ok so in case anyone gives a s*** or not, here's what happened with the inop engine brake. Before I started troubleshooting this thing, the owner went down to the local Peterbilt dealership parts department for a new engine brake on/off dash switch just to throw an easy part at it and see if it cured the problem. He brought the old 4 blade switch with him along with the VIN. Parts guy brings out a 2 blade switch. Owner questions young guy behind counter, parts guy had 2 others behind the counter reassure him that the 2 blade would work in place of a 4 blade. He took their word, swapped switches out. Still inop...
I had Insite linked up a while back, all visible PIDs were functioning OK. Even engine brake on/off. That's all I had time for
Fast forward to today. I finally got back on the truck. Started locating all the things that make the jake's work. All was checking out ok. Finally found where all the cummins celect stuff is in the cab, (just to the right of steering column a fuse block and a relay block) found engine brake relay. I had no trigger power at pin 85 of relay.
Ended up getting back to brake on/off switch. At this point I didn't know the owner had swapped switches... Remember that 2-pin/4-pin thing? One pair of pins is 5v from the ecm, 5v gets sent to ecm when switch is on. Other pair is the 12v trigger side of the engine brake relay. This is the pair of pins that was missing from switch. I was getting the signal to ecm but no power to relay. That's why Insite would show the engine brake functioning on/off. Easy fix at that point. Got a 4 pin 2-pole switch, engine brake working fine.
My point here isn't about the troubleshooting. This was probably elementary for most of you veterans. My point is the guys that promised the owner "this is the right switch". when a guy lays a 4 pin switch on the counter, they hand him a 2 pin and say you don't need the 4-pin.... see this kind of stuff all the time. Owner said they were a bunch of young guys with attitudes, could tell they could care less of the switch was right or not.
What's it take for a place to get a good parts guy??? Or one that gives a s***. No one cares anymore. Do these parts houses not think that a good parts guy is key to a successful business??
There's a NAPA in town, had THE best all around truck/equipment parts guy i have ever met. Used him heavily in October/November after the fires when our equipment was running 24/7 at work. 2 months later I found out that he got a sweetheart offer to go run the parts department for the biggest construction company around. NAPA probably had no clue what they were loosing. Being that parts are Their money maker, I would have doubled his salary. Especially due to the fact that anyone else working there will ask if my truck is auto or manual and 4x4 or 4x2 when buying wiper blades.
Someone rant with me
