Georgia Iron
- Joined
- May 6, 2012
- Messages
- 882
- Location
- USA - Georgia
- Occupation
- Concrete building slab and grading contractor
Using the loader on the dams banks to clear downed trees and brush.
After using the loader a good bit clearing downed trees on the dams banks.
I found out it is important to:
1. Make sure the hydro stats fluid is full. (That was what was giving me the no power problem on the grades).
2. Keep the pads angled so that you keep traction and do not slide sideways.
The loader will not go up this incline forward. It spins.
The bottom photo shows the lakes drain pipe that has a small stream under it. The loader floated right across the creek pushing a large pine that had fallen into the spill way. The picture shows the top of the pine tree. The tree goes on for another 90 feet. Being nervous about getting the rear end down into a mud hole. I reversed the machine straight back out before crossing back over onto hard ground. On reverse it started to sink into the mud. It went down about 18" and the belly was just starting to slide on mud. The LGP tracks floated the machine very well. I however do not want to find out what happens when they break free and start spinning. So once in and out was enough for me.
The CAT 953 is a really nice machine to use to do any kind of work around property. It moves fast and has a lot of traction. It will go places that you might be better off not taking it. I really like the A model that I have. It is good on fuel and seems to have good power for what I am using it for.
