frank@signsfors
I have a truck that has been sitting since 2010. It is not running. It turns over, It was not getting gas, I replaced the fuel pump and now am feeding it from a gas can. It is now getting gas
I don't think it was getting spark, I replaced the distributor cap, rotor and coil. still nothing. there are 4 wires into the distributor cap, a red, yellow and two plugs. I guess red is 12 volts, yellow is grounded through the ignition switch???
The plugs are Autolite 144s, they are carbon coated
I had it running today for about 30-40 seconds, then nothing
What could be holding it back? Maybe a fuse? fouled plugs? bad carb?
