leisureexpress
Hello all, I have been lurking here for the last 6 months and have gotten many of my questions answered. But I have a few more....... I know that many people prefer the Case TLB's from the same vintage, but this is what I ended up with, well that and it is very similar to the first one I started running when I was 12 years old.
On the JD410, it runs good and has strong hydraulics. A couple of the things I want to fix are:
1) The brakes. They both work and the right one is the better of the 2. I can push it down and it takes more pressure than what I think is normal, but it works. The left one is way stiffer, takes even more pressure but will not return to the retracted position. Are there any common things to look for to free up the pedal action of the brakes and linkage?
2) The clutch. It seems to all come in or out in a very short amount of travel - the top 1/2" of travel. It is very hard to do anything smooth in close quarters. The reverser works fine. Maybe it is normal for this machine and I am spoiled with the newer torque converter machines 310D and 310E that I have spent a bunch of time on.
3) Hard starting after stalling. It starts pretty good when cold - from what I gather about this 4219 engine just the fact that it does start by itself when it is 25F with no ether is about as good as it is going to get. The problem is after it stalls warm or cold, the motor will crank over a couple of revolutions and the battery acts dead/weak starter. (I have checked and changed the batteries and had the starter gone through, cleaned the cables/grounding points - thanks to tips found on this forum) About the only way to get it started is to wait about 5 minutes and it fires right back up, that or jump start it. It feels like the hydraulics are loaded, and dragging it down, but no relieving of any of the hydraulics front or back helps. It just takes 5 minutes and it is up and running.
I have a couple of more small issues, but will leave it at this for now. Thanks in advance for any tips!
Happy Holidays!
Happy Holidays!
