If we are talking about the loader lift and bucket valve, I slip it off the machine to change the spool seals. They had two different valves, a dukes and a Cessna, The dukes had a in closed end cap on the loader detent housing and the Cessna seems like the detent stud came threw the end housing. After cleaning the valve remove the screws that hold the centering spring, detent housings. You may have to tap them with a small hammer to loosen the paint, leave the cap installed on the loader spool and slide the spool out the rear, clean, install new o rings, lube the spool and reinstall, tighten the end cap screws. The bucket end cap can come off, remove the spool to the rear, clean, install seals, lube, reinstall, replace the end cap. Install the valve back if removed, check fluid, test. Always release hyd pressure, and tank pressure before servicing system.
