chris dials
I’ve got a cat 160h that has lost all forward and reverse
Had a stick come up and broke an air fitting under the cab which caused low enough air pressure that the parking brake set. Was able to build enough pressure to get the grader off the side of the road. Fixed the air leak, but now I have no forward or reverse. Doesn’t even try to engage. Is it possible the transmission took a **** right then ?
