Scrub Basher
I'm running a Series I 12H. The countershaft, fan and alternator pulleys are worn out. I can get the countershaft and fan pulleys machined down and a new steel pulley made to replace the worn cast alternator pulley for about $1100 AUD less than buying all new pulleys from Caterpillar...but the countershaft and fan pulley diameter will be reduced slightly by the machining process. The new alternator pulley can be made a little oversize to compensate for the reduced diameter of the other pulleys so the standard v-belts can be used.
Question: can you see any problems with going down the path of slightly undersize countershaft and fan pulleys and a slightly oversize alternator pulley?
