Hi Wrench1 I am new to this but here goes if I muck up I apologize in advance
if blade drifts with engine off there are 4 possible causes
1.external (visible) leak
2.leaking cylinder seals
3.rod end line relief
4.lock check valves .
To eliminate check and line relief swap valves from right hand lift control valve section.
if lock checks and line relief are good lifting machine off the ground is not a good indicator of condition of cylinder seals.
Here are a couple of ways to check cylinder seals .
!/ release cylinder cap from ball, operate left joystick and extend cylinder to end of stroke remove hose from rod end of cylinder cap hose with steel ORFC steel plug, fit temporary hose to cylinder fitting to direct any bypass oil to a suitable catch bucket. operate joystick in same direction
If seals are ok not much oil will escape from cylinder. repeat test with rod retracted
Sometimes the cylinder barrel is belled out part way along cylinder length ,to check for this condition is quite easy but care is required do not use full pressure of hydraulics remove hose from piston end of cylinder cap cylinder port and hose end. Operate machine and attempt to move lift cylinder, if cylinder moves this indicates seal bypass at the position of the cylinder rod in the barrel if it doesn't move indicates seal is good
reposition the rod before capping and you can test different parts of the cylinder for bypass
Caution if the seals are good and the piston end is pressurised and rod end capped extremely high hydraulic oil pressure can be developed in the rod end of the cylinder and could cause the rod end seal to fail or personnel injury. An external relief should be fitted.
If blade drifts with machine running could also be calibration of left joystick go to cat messenger main menu scroll to service menu scroll to parameters scroll to implement scroll to blade L lift position this will give you a figure in % should be about 50% +/-5% with joystick centred anything higher than 55% or lower than 45% will need calibrating moving the joystick within these limits should produce no movement of lift cylinder
Regards
Mark250
PS I have a lot of info on m series but I don't seem to be able to post pictures but I can email if you like or if someone can help me through adding pictures screen shots and graphics
