1 1/2" fuel filter base
Discussion in 'Lubrication' started by rdr, Aug 8, 2017.
  1. rdr
    rdr Active Member
    Dec 25, 2007
    36
    usa
    I hope this is the right place to ask this ?. setting up a fuel truck need a filter set the ones we are using are now $450. us is there a cheaper one out there [we are using 2 mioncron filters in ours ] thanks ron
  2. kshansen
    kshansen Senior Member
    Mar 11, 2012
    4,297
    Central New York, USA
    A little more info or maybe even a picture would help someone give you useful information.
    Like is the 1 1/2" the pipe thread size on the filter head?
    What does this filter supply fuel to?
    How many gallons per minute do you need to pump/filter.
    Maybe even a make and part number of the ones you are using now?
  3. Junkyard
    Junkyard Senior Member
    Jun 5, 2016
    998
    Field Mechanic
    Claremore, OK
    2 micron on a fuel truck seems awful tight to me....on the engine as a secondary I can see it. 1-1/2" as in inlet and outlet?
    Good lord $450? How long they last?
  4. lantraxco
    lantraxco Senior Member
    Jan 1, 2009
    6,678
    Elsewhen
    Don't know if it's legal, but in the past I used standard hydraulic filter heads and spin on filters, Zinga is good you can get 3 micron. I used to run two in series, the first was a 10 micron "Aqua-Zorb" to trap water and then a 3 micron synthetic media, both set to no bypass, the pumps we used would deadhead without a problem so when the filter clogged up fuel would just stop flowing. http://www.zinga.com/
  5. rdr
    rdr Active Member
    Dec 25, 2007
    36
    usa
    sorry 1 1/2 " pipe thread for fuel on mobil truck [ use cim-tek centurion ii filters on other pumps ] ron
  6. rdr
    rdr Active Member
    Dec 25, 2007
    36
    usa
  7. rdr
    rdr Active Member
    Dec 25, 2007
    36
    usa
    60 gpm 50psi
  8. lantraxco
    Jan 1, 2009
    6,678
    Elsewhen
    The setup I mentioned, two hydraulic filter heads, two spin on filters, 80GPM at 200 psi max, you could get the pieces for about $150 plus shipping. Replacement filters run $35-$40 typically. Racor was always the gold standard on the tugs I worked if you have to have something mainstream though.
  9. rdr
    rdr Active Member
    Dec 25, 2007
    36
    usa
    thanks I will look in to the racor as it will be handle the psi and gpm and the price is good don't care about legal
  10. Junkyard
    Jun 5, 2016
    998
    Field Mechanic
    Claremore, OK
    Lantraxco went where I was headed. Should work out well once you source the parts.
  11. rdr
    rdr Active Member
    Dec 25, 2007
    36
    usa
    junkyard there is a dealer in Tulsa next time I go to kencool sorry [wb ] to get ac supplys I will check them . as of late I just have them ship up to us thanks ron
  12. rdr
    rdr Active Member
    Dec 25, 2007
    36
    usa
    lantraxco thanks for the tip napa got me the parts all done for $ 87.00 base and filter
